Uniden DECT 6.0 Cordless Phone ID Logo
Virginia Renda Posted on Sep 22, 2015
Want to change how fast the answering machine goes on.
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Goes to answer machine to soon
The 6041 isn't an answering machine. To change the ring count, consult the documentation for whatever answering machine you have on your phone line.
If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
2helpful
I have a Wispa yellow fold up Mobility scooter bought 2nd hand and want to know if it is possible to fit new batteries myself 2 x 12v as it is not reaching 4 miles an hour on a full charge and battery...
Several suggestions.
1) Since likely not a lot of "question answerers" at Fixya have one of these, ask on social media or wherever you can find an answer "how fast should these things go?"
2) After running yours for a while, carefully check the temperature of the motor ( motors) and see if they are hot.
If so, they may be "tired" and are using too much voltage.
3) You can probably change the batteries, but depending on where you live, you may or may not be able to do this easily.
4) Test the motors with the wheels off the ground, and see if the machine goes faster.
If it goes faster, check the wheel bearings for binding.
God bless your efforts.
1helpful
Sewing machine goes too fast.
If you undo the foot control you can adjust the screw on trhe end of the spring if you have the button type foot control
My uniden phone rings and goes to answering machine in 2 rings
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
My mobile goes direct to answer machine without ringing
your service provider will provide you with a code to alter the settings for the answer phone , you can adjust how long before the answer phone kicks in and whether the answer phone is on or off
Jul 19, 2009 • Cell Phones
Changed brushes still wont fast spin and empty water
Let me ask you who told you to change the brushes... Im curious!
Have an old hobart handler, wire goes fast then slow etc. already
this is wierd .if your getting an ok bead i would nt change the machine any.is the gas on?change the setting some go up on the wire settings slow .go up on the amps slow. the machine should sound like bacon frying consistently fast.try that and see how it goes.jojogunn
My hotpoint aquaris machine is not engaging the fast spin function. When it comes to the fast spin in the cycle the machine goes dead. The machine was performing the fast spin until recently however the...
everything you have described points to a blocked pump,worth blowing down the clear pressure pipe from the switch end while your in there to make sure thats clear!
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
