Question about Korg D888 8 Track Recorder
Why cant i connect to my pc anymore
It use to connect every time now its making a sound like its connected bu it doesnt show up
    Top Expert:
  • Korg Master
  • 3,156 Answers
If you have updated your computer OS it may no longer be compatable. Other than that do a herd reset on the Korg and see if that helps.
Posted on Sep 23, 2015
SOURCE:
Lo, i have a fender frontman 65 r, bought it 2 years ago, my problem with this amp is that it produces disturbing like thunder sound at the middle of my playing, i checked and change the cable and also...
It could be dirty interupt contacts on the jack you are plugging into. Spray some conct cleaner from the back side and plug and unplug a few times to see if that clears it up. Also spraying the controls and switches- make sure you get the spray stream into the switch or potentiometer to get on the contacts to disolve grime.
Other potential sources are poorly soldered connections on the amp chassis- litterally anywhere. Reflowing all solder connections would likely remedy the problem.
Also make sure the nuts that retain the jacks to the amp chassis are snug and will not move.
Apr 01, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I have a clavinova that doesn't make sound
Try the headphone jack... if there is sound there, then it is either the speaker amplifier or a loose cable. It would be rare for BOTH speakers to fail completely.
Aug 29, 2011 | Yamaha YDP223 Digital Piano
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Mar 27, 2011 | Yamaha YPT320 61 Key Personal Keyboard
When I connect my Privia PX-130 to my computer (and Logic) it works perfectly but if I connect the audio out (via line out) at the same time, the audio sounds dreadful, even if I'm not going through the...
I SUSPECT that the USB connection is ECHOING the data, causing multiple generators to be active. Those extra ones then are mixed into the line out of the keyboard. In your PC, make sure the echo setting is turned off, OR disable the sending out of audio via the USB. Alternatively, DISABLE MIDI/USB incoming to the keyboard.
Jan 21, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
When I connect my guitar to the V-Studio 20 it doesn't catch the sound. i installed the drivers and everything but it still doesn't work what shud i do?
Open the "sounds and devices properties" in the PC control panel and make sure the input and output show that the V studio IS the input and output... If not, select those. Often you will find that they have defaulted to the PC internal audio board.
Dec 09, 2010 | Cakewalk V-Studio 20 Stereo Audio...
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hello. I riencently bought a used Lucille, which
Try looking here:http://www.gibson.com/en-us/Support/FAQs/# scroll abut half way down to the black printing.
Oct 21, 2009 | Epiphone B. B. King Lucille Electric...
After hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Jan 29, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Korg D888 8 Track Recorder Logo
44 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
