Go to the Buick dealer, talk to the service manager, tell them your kid did it..(because they will not help you if they know you went somewhere else to get work they do).. and ask them how to fix it.....then go back to the Valvoline place with your new found info...
Depending on what you broke, an external flash might not even work. The best solution is to send it to Nikon for repair. There number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. The alternative is to find a local camera repair man. This is not a do-it-yourself job.
SORRY, if the panel (it is called a display panel) is damaged this is the end of this set- fatal from a cost point of view as the part if available will cost more than the set did when brand new.
The display panel in all these sets is fragile as you have discovered--even a minor hit can destroy the panel.
Recheck the tv projection lamp installation?Recheck the lamp door latch,see if it is proper closed and tightly closed of the lamp door?Hear any clicking noises,when the tv projection lamp tries to ignite up.If hearing constance clicking?Mean the tv board that call the Ballast board it is also dead,this Ballast board only job are to ignite the tv projection lamp only.Ballast board must have be replaced.If the tv have a colors wheel is it dead or damage and broken require changing,u will hear major humming,motor or grinding sound noises and alot of times the tv pictures flashes multiples colors on the tv screen or the tv pictures will have a black&white flashes of a background of white light within the tv pictures background.Selling defective tvs almost impossible to sell it for a decent or a good priced or it at all.If this tv u have less than 5 years old,tv it is still have alot of it life ahead of it,tv tube picture screen panel,will last u atleast another 10 years and have to be 8 hours tv whatching every day to dies this faster or could be last to 15 years,if tv less hours of watching every day.Should get priced quotes from many tvs repair shops and get it fixed max prices about $400-$500 dollars.New tv same model and sized or difference models too will cost u like $1,200-$1,500 dollars.
If u move the tv pictures come back on clear and good,no bruses to the pictures at all?Yes,this tv can be fix the PCB main board is cracks or borkens,could be mend to it by steal rods and solder joints by a tv tech. to fix it.But if the pictures have bruses in it.The tv picture tube is damage,sorry this tv garbage,not worth fixing.
Tv have convergence problems first,fix the convergence board first.The tv have mis R,G,B colors lines alignment have 3D pictures effect.The tv convergence board have totoal dead 2 ICS convergence ICS and some or all it resistors.U know how to do basic's soldering?U have tools like a soldering iron,desoldering pump or solder witch and solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy ur tv make and model of convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.Now,the projection lamp, might need to replaced too,after fixing the convergence problems.
The deflection board needs replacement. You can get the ITC222A deflection board PSB-260 from www.tvrepairworld.com which comes with instalation instructions
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
