I bought the machine used. The seller did not include an instruction manual with the machine. It is not easy to operate the machine without a manual. I want my daughter to have it to do her crafting. She will need the instruction manual to learn how to operate the machine, especially how to thread it.
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
SOURCE: TS 380 Tiny Singer Serger Manual - Threading
If you go to this page:
http://www.singerco.com/accessories/manuals.html
at the search box, type in just the model number, ts380, and click search.
at the results screen you'll the "Free Download" for this manual (PDF format). (there are also options on that page to have them mail you one; but luckily this is one which also has a free downloadable version!)
Enjoy serging!
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
SOURCE: manual needed for white 734dw superlock eclectronic serger
I talked to custom service at White Sewing Company at 800-331-3164 and they directed me to a website to download the manual for free. Go to www.singerco.com and search for "wsl734" (white superlock 734). It probably has other manuals but I wouldn't have known what model number to search if she hadn't told me.
SOURCE: How do you thread the brother 1034D serger? A
You can download a free manual at the Brother website http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
