Suntech 305W PV module STP305-24-Ve poly Logo
A
Anonymous Posted on Sep 20, 2015
I need to know what kind of inverter I need for a solar system consisting of four 305w solar panel, connected in cerise.
305w. VOC--45.29 SC--8.95a. IMP-35.77v
Brian Lee
Level 2:
Scholar:
New Friend:
  • Expert 123 Answers
  • Posted on Apr 18, 2017
Brian Lee
Expert
Level 2:
Scholar:
New Friend:
Answers
123
Questions
0
Helped
65765
Points
422
With so few panels, you could use microinverters in parallel instead of series, such as from Enphase
https://enphase.com/en-us/products-and-services/microinverters/family
But if you want to stick with series, then a 1.2 kw string inverter is what to look for. Perhaps something like these
http://www.micromaxenergy.com/pdf/String-Inverter%20(2).pdf
1helpful
2answers
Can you connect FBI2000W inverter to solar panels?
Yes, it is possible to connect an FBI2000W inverter to solar panels. In fact, inverters are an important component of solar power systems, as they convert the direct current (DC) electricity generated by solar panels into alternating current (AC) electricity that can be used to power homes and businesses.
To connect the FBI2000W inverter to solar panels, you will need to:
  1. Install the solar panels on your roof or other suitable location and connect them in a series or parallel configuration to achieve the desired voltage and current output.
  2. Install a charge controller between the solar panels and the inverter to regulate the flow of electricity and prevent overcharging of the battery bank.
  3. Connect the output of the charge controller to the input of the FBI2000W inverter using appropriate wiring and connectors.
  4. Connect the output of the inverter to your home or business electrical system, following all relevant electrical codes and safety guidelines.
It is important to note that connecting solar panels to an inverter can be a complex process that requires specialized knowledge and expertise. It is recommended that you consult with a professional installer or electrician who can help ensure that your system is properly designed, installed, and configured for optimal performance and safety.
I have moved into a hous and i do not know how to ise growatt that was inside my house already.
That appears to be for a solar energy system, you should have solar panels on the house if you have that. If the unit is small and has an antenna then it monitors your solar power and reports what the inverter on the outside of the house is producing to whomever is your solar provider. IT requires an internet connection to do this. http://growatt-america.com/
2answers
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
What kind of solar panel would i need to power a grundorf jp 5
It depends on many factors. What is your geographical location, in very hot climate generally poly panels do a little better and you need to match your charge controllers input with the solar panels. sometimes for small systems big panels with higher current ratings do not do well.
2answers
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 • Plumbing
2answers
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
3helpful
4answers
Pls i need an answer
Solar panels come in different ranges of wattages.Add up the wattage of different solar panels you get e.g. Ten 100W solar panels will give you a 1Kw solar system.
Top Suntech Renewable Energy Experts
Mark Ultra
Florinda Byers
Level 1 Expert
Are you a Suntech Renewable Energy Expert? Answer questions, earn points and help others
