SkyScan 86742 Digital Atomic Wall Clock Logo
j
john sabolich Posted on Sep 20, 2015
Is there a way to simply move the time foward a single hour. and is there a way to set it behine a single hour. for day light savings etc thanks
6helpful
4answers
Accutime batman watch time setting
if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Apr 03, 2013 • Watches
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
1helpful
I have a Woods 24 hours indoor lighting timer. I have followed the instructions provided with the timer, but lamp won't come on. Can someone please provide EXACT step by step instructions. Thank you
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
6helpful
2answers
My text messages received time is an hour behind
go on your time and date settings, select time zone and put GMT 1 (this is for UK) then set the correct time and save. and it should all be da same!!<br /> <br /> i had the same problem and now its fine!<!-- from fixya rte -->
7helpful
4answers
I HAVE A CASIO 3054 WAVE CEPTOR WV-58A WATCH. It
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
97helpful
13answers
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 • Watches
5helpful
4answers
Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Dec 24, 2007 • Watches
4helpful
Setting the time
At extension 1
press Program (mute light turns on)
press Transfer (mute light flashes)
dial "38"
enter 2 digit year, i.e. "08"
enter 2 digit month, i.e. "05" = May
enter 2 digit day, "01" = first of the month
"31" = last day of the month
enter 1 digit day of the week
1=Sun, 2=Mon, 3=Tue, 4=Wed, 5=Thu, 6=Fri, 7=Sat
enter 2 digit hour in 24-hour format
00=midnight
01=1 AM
13=1 PM etc
enter 2 digit minute from "00" to "59"
press MUTE.
You will hear a single confirmation beep. If not, you did something wrong. Start again from the top.
3helpful
2answers
Set time on motorola v323 phone
Hey, just turn your phone off for about 1 minute and then power it back up, it should reset the correct day light savings time on its own. Have a good day!!
Nov 04, 2007 • Cell Phones
Top SkyScan Home Experts
john h
Paul Carew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
