Frigidaire FEF376 Electric Kitchen Range Logo
Posted on Nov 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire range the door is open but the lock is on and I can not get it to unlock
  • 1 more comment
  • l8trg8tr Nov 20, 2007
    the model is FEF376CJSA if you need anything else let me know. Oh it is a frigidaire gallery if that helps any.
  • l8trg8tr Dec 15, 2007
    There wasn't a tech sheet on the back panel. But now the oven isn't working it keeps coming up with F3. We tried to turn the lock motor by hand and it wont move. The clean cycle will not come on either now.
  • 666killer Dec 25, 2007
    plgfz390ecf is the product number, the door will open but remain locked
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
777
Points
5
Unplug the unit, then manually depress and hold the light switch on the frame of the unit while plugging it back in. The lock should go back into the proper position.
Craig Mac
Anonymous
Level 1:
  • Posted on Jan 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
777
Points
I had a similar problem. Turned out that the locking road hung up and the motor wasn't powerful enough to move it. So I removed the two screws that hold down the cooktop and freed up the locking rod. Then I turned the range back on with the door open, but holding in the door switch as if it were closed. the lock then completed its locking cycle. Then I was good to go. Hope this helps somebody else.
Anonymous
Level 3:
  • Master 473 Answers
  • Posted on Nov 16, 2007
Anonymous
Master
Level 3:
Answers
473
Questions
Helped
451969
Points
1483
Try this first:
Turn off power to unit.
Open the door.
Turn power back on.
Hold in on door switch until lock cycles to unlock.
If this doesn't work then the door lock motor may need to be replaced.
Anonymous
Level 2:
  • Expert 290 Answers
Anonymous
Expert
Level 2:
Answers
290
Questions
Helped
313711
Points
924
Try holding in on the door switch and starting a clean cycle. Let the latch rotate around and the cycle start, then cancel the cycle and the latch should rotate to the unlocked position. You will have to keep the door switch pressed during all of these steps.
Post back and let me know what happens.
  • 2 more comments
  • Anonymous Nov 18, 2007
    If you will post the complete model number from the range I can probably tell you how to manualy move the door latch and check the components.
    The most common problem on the frigidaire ovens is the door switch failing.
    Thanks/Mike
  • Anonymous Nov 20, 2007
    Pull the range out and unplug it. Remove the rear panel and you will see the door latch motor mounted to the rear of the oven.
    Try turning the motor manually to unlock the door. You may have to take the motor loose and unhook the rod that goes to the latch at the front.
    You should find a tech sheet on the back of the oven that will tell you how to check the lock circuit. I usually find the door switch to be the proplem but it could be the motor or oven control.
    Mike
  • Anonymous Nov 30, 2007
    Just wanted to see if you were able to get the door latch back in place.
    Thanks/Mike
  • Anonymous Dec 16, 2007
    F3 is the code for a failed temperature sensor. Either the sensor is bad or the control is not reading the resistence properly. Make sure the wire connector to the sensor at the rear of the oven is plugged in properly. If so you probably need a new sensor.
    Pull the drawer completely out of the stove and see if there is a tech sheet stuck to the inside of one of the side panels.
    You can go to sears.com, click on parts, enter your model number, and you can see a wiring diagram along with a parts list for the stove.
My oven door will not open. The motor cycles and locks then unlocks door opens slightly but will not ocme open.
I appreciate your post, friend!
Based off the information you have provided the door on your Frigidaire range will not unlock. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not work you can attempt to start another clean cycle and right before it starts press the cancel button. If neither trouble shooting step unlocks the door your latch may be broken. I would then recommend having a professional technician perform a diagnosis and repair. I hope this helps. -Matt
1helpful
Oven door won't unlock after cleaning. First time using cleaning system. No error message. Locked since yesterday. Unplugged and still locked. Doesn't say it's locked but won't open.
Good Morning Kay Warren, I appreciate your post!
Based off the information you have provided the door on your Frigidaire range is locked and will not open. If you look on your control panel you should see a clear or cancel button, hold that down for three to five seconds. This should unlock your door. If this does not unlock the door you can attempt to perform a reset. You can do this by disconnecting the power from your range for ten minutes. I hope this information is helpful. -Matt
How can I get my Frigidaire model FGF379WJCA is in lock mode with door open. How do I get it unlocked. I've had this stove for 14 yrs?.
Good Afternoon Friend, thank you for your post!
I recognize that the door of your Frigidaire range (FGF379WJCA) is locked with the door open. Here are two few simple troubleshooting tips that may help you resolve this issue:
    1.Press and hold the "CLEAR/CANCEL" button to stop any operating of the EOC (Electronic Oven Control). (Do this at the same time as step 2).
    2.At the same time, push and hold the light switch (typically located to the left of the door lock). This normally tricks the oven into unlocking the door.
This normally tricks the oven into unlocking the door. If these assessment measures prove to be ineffective, I would suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair your range. You can often locate an experienced technician in your area by going to the manufacturer website. Best regards! - Z
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
2helpful
Frigidaire FES367FCC. Oven is flashing F90.
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
3helpful
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
8helpful
Frigidaire CFEF372BC2 electric range - oven door won't unlock after cleaning cycle
Hi .The oven door will not unlock until it cools down despite the cycle being finished.If it has not opened in a maximum of 1 or 2 hrs then oven sensor failed during self clean cycle and will have to be replaced.Try restarting self clean to unlock door .If not you will have to do the old coat hanger trick or manually move the lock mech. from rear,sensor cost $30-40.Hop this helps .Please rate my response :)
Beeps - won't stop - f90 code - thinks door is locked.
unplug the range.
wait 1 minute.
wait 2 minutes.
Frigidaire, Gas Oven Door
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
10helpful
5answers
Frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
