No sure but when I had the problem the dealer told me they need to drive the car for about 50 miles to allow the computer to cycle through all the programs. Hope this helps.
P0452 evap control pressure low, P0 446 evap vent contol circuit. Becuase you have P0452 you are dealing with a eletrical issue whether you have positive tank pressure or negative pressure, The tool for this is a volt meter.452 happens when you positive pressure and the FTP reads less than 0.1 volts.You need to jump the signal and the reference and monitor the take parameter on a scan data you should read reference voltage.Now if you dont have a scan data tool. inspect the wire for any breaks or shorting 2 thing of concern broken wire to the FTP or a ECM is needed.
has the battery been disconnected, drained, or computer codes been cleared? all of these will erase readiness monitors in the computer and will have to be driven to reset it's hard to say how far because it varies on different vehicles
you might try unhooking the battiey for 20min both + and - posties cuz that will force the computor to have to resest only if you have addressied the fuel pressure problem which taht would most likly be your filter which isn't all that much
