Question about Yukon NVRS Titanium 2.5x42 Gen 3 Night Vision Riflescopes - 2603
I want to remove the IR, Redical adjuster and Battery box.
  • Yukon Master
  • 2,195 Answers
Why . interested in making an expensive paper weight
Posted on Sep 25, 2015
SOURCE:
Just purchased a new 3V CR123 battery for the prowler. The lights are working whenever i click ON or IR, however when looking through the lens nothing is visible. It's just all black. I removed the...
Jello, you meam that IR isn't emitting red light? If the IR isn't working then it has a bad IR luminator, broken wire, bad switch. Now the on/off switch get it power from battery to IR, it just one simple circuit. Also don't look at the IR light if it's on. Also don't point or look at bright lights with this NV devices, it will destroy the image intensifier tube. stewbison
May 30, 2011 | Bushnell Prowler 26-4050 Monocular
Barska Excavator 8-32x50 scope. Where is the battery? I assume within the turret to turn on the light and for adjusting brightness? How is the battery cover removed?
  • This scope does not use batteries. It uses an IR or Illuminated Reciprocation. The light available is guided through a light track and illuminates the dot. The setting adjustment is used to allow less or more light through to illuminate.
Regards, Tony
May 02, 2011 | Barska Optics Barska Riflescope Excavator...
I have a 1990 supreme cutlass and i don't know how to change the serpentine belt. What do I do?
2.8L and 3.1L Air Pump Belt
  1. Disconnect the negative battery cable.
  2. Loosen the air pump.
  3. Remove the worn belt.
To install:
  1. Adjust the belt to specifications and tighten the pump mounting bolts.
  2. Connect the negative battery cable.
2.3L Power Steering Belt
  2. Loosen the adjustment bolts.
  3. Remove the power steering belt from the pulley.
To install:
  1. Route the belt around the pulley.
  2. Adjust the belt to specifications, then tighten the adjustment bolts.
  3. Connect the negative battery cable.
See Figures 6 through 15
Fig. Fig. 6: Unfasten the retaining bolts...
Fig. Fig. 7: ... then remove the serpentine belt guard
Fig. Fig. 8: ...
Fig. Fig. 9: ... then remove the serpentine belt
  1. Remove the belt. Clean the accessory drive belt surfaces.
Fig. Fig. 10: Serpentine drive belt routing-2.2L engine
Fig. Fig. 11: Removal and installation of the serpentine belt-2.3L engine
Fig. Fig. 12: Serpentine belt routing-2.5L engine with and without A/C
Fig. Fig. 13: Use an 18mm box end wrench on the pulley nut to rotate the tensioner on the 3.8L engine
Fig. Fig. 14: in. breaker bar to rotate the tensioner
Fig. Fig. 15: On the 3.4L, use a box end wrench, then rotate the tensioner clockwise and remove the serpentine belt
Remove the belt guard or coolant recovery reservoir as required.
Dec 31, 2010 | 1994 Oldsmobile Cutlass Supreme
NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Jul 28, 2010 | Samsung Televison & Video
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
Error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Jun 03, 2010 | Canon imageRUNNER C3200 Copier
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
Mar 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Does the Comcast remote work in IR and UHF? Infrared and UHF(able to go thru walls or floors.
Depends on the converter box but chances are yes its has both communications.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | RCA HD52W59 HDTV Projection Television
Broken date adjusting stem
We do that kind of work. just send it in. www.finewatchmaking.com
Aug 29, 2007 | Polar (Ir) Infrared Kit (Serial Port)
TV won't respond to remote(s)
I don't know of any adjustments for the IR receiver but the receiver itself could have gone bad or something may be blocking the IR lens not letting the IR signal get through. Maybe (but unusual) there may be a cold solder joint in the IR circuit. Sometimes dust will collect on the inside of the IR lens causing this problem. You can verify the operation of your remotes by holding them close to an AM radio receiver and pushing the buttons. You'll hear a popping sound through the radio speaker whenever a button is pushed. You may have to tune the radio up or down the band to pick up the remote's signal. Stargazer
Mar 02, 2007 | Toshiba 34HF81 34" TV
Yukon NVRS Titanium 2.5x42 Gen 3 Night Vision Riflescopes - 2603 Logo
71 people viewed this question
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
