Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
I've wound hundreds of bobbins on my machine, but suddenly with the bobbin winder engaged and showing up on the screen as winding bobbin, it will stop after a few revolutions, and all the while the machine is also in sewing mode (needle going up and down although not smoothly) The winding mechanism goes back and forth smoothly, everything is correct on the screen, but now I just get beeping when I try and wind a bobbin. I take good care of my machines and have then serviced routinely. Any ideas before I take it to the Janome repair shop?
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Hello Kathy
Make sure that:
1. The correct bobbin is being used ... make sure that the bobbin is the one specified for your machine.
2. Make sure that the bobbin is pushed all the way down on the bobbin winding spindle.
3. Make sure that the bobbin winder is engaged ... pushed over for winding.
4. Make sure that the thread is not tightly wound around something preventing it from advancing onto the bobbin.
5. Refer to page 18 of the Manual. If you need one, it is available for free at: PFAFF tiptronic 6232 Instruction Manual Page 22
May this get you back to sewing very quickly. Please give me a thumbs up if this is helpful, otherwise send me more information.
Sewingirl/
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
I'm not sure what you mean about this. When you want to wind a bobbin, you put it on the bobbin winder pin on the upper right side of the front of the machine, and then push/slide it down towards the bottom of the machine; it goes about an inch or so, and then the screen will say "bobbin winder engaged." The bobbin is now in line with the fat lever that will automatically stop the winding when the bobbin is full. (I usually use my fingernail to guide the thread up and down a bit so that the bobbin is wound smoother.) If you have the same manual I have, that came with my machine about 4-5 years ago, the two pictures on the bottom right-hand side of page 10 will show you what I mean. -- BTW you can wind a bobbin with the machine threaded or not threaded. (pages 10-11) Also, always be sure to wind the bobbin with the logo-marked side up, the same way you place it in the bobbin holder when you are ready to sew. -- I hope this helps.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
