SOURCE: Can i use the charge key to record credit card payments using the casio pcr-t2000 cash register?
You sure can. It will show the word charge on your daily reports. that is the only difference. Just a label for the same key
SOURCE: How to make silent keypad on casio se s300 cash register?
page 61 key catch tones.
http://support.casio.com/storage/en/manual/pdf/EN/006/SE-S300_EN.pdf
SOURCE: I have a casio pcr-t500 cash register I just need some help to program my tax rate.
It is in the user manual, around page E-65:
http://www.manualslib.com/download/719074/Casio-Pcr-T500.html
Be very careful. The machine is trying to wipe all of the programming due to a flat battery (you can't store cash registers for more than a month or so). Follow this very carefully:
Turn key to PGM (program) mode
Turn power off at the wall socket
Hold down RECEIPT FEED button (keep your finger on it)
Turn power back on and wait 5 seconds before taking your finger off of the receipt feed button (the paper may feed out. This is normal).
The LLLLLLLLLL part of the display should change to FFFFFFFFFF.
Press SUBTOTAL once and wait for the printer to issue a receipt.
Turn key back to REG mode and try it. You may need to sign on using a clerk button or a clerk code if you use one.
If the memory is scrambled and your programming has vanished, you will need to clear the machine and start again. There is a full programming manual online. the only one I know of is here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
