Be sure to RAISE the presser foot BEFORE threading the upper thread. This releases the tension disks so the thread can be seated properly.
Balancing Thread Tension - Janome MEMORY CRAFT ...
www.manualslib.com > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
SOURCE: Janome Memor Craft 10001 bobbin tension
Hi, There is an adjustment on the side of the black bobbin case. Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time! Good luck
SOURCE: tension problem
For Staight Stitch.
Ideal
When adjusting top thread the Higher the number (on the little wheel) the tighter the top thread.
Results depend on
Stiffness and thickness of the fabric, number of fabric layers and type of stitch.
Are you using paper or a plastic bag or pellon under the fabric? This gives a smoother surface for embroidery (on the reverse) and you can cut it away after the design is complete.
Susan
SOURCE: My Memory Craft 3500 suddenly
It could be a wad of lint in the upper tensioner disks keeping the disks apart. I have also seen on older machines where the thread has actually cut a groove into the disks. If you can dis-assemble the tensioner, clean and inspect. Be very careful to memorize the part order in which you remove the parts, this will help when re-assembling it.
Good Luck,
Chris
glfi.com
SOURCE: janome 350e how to adjust tension
Looping thread underneath is a top thread tension issue... I have written a 5 page illustrated Tutorial on overcoming this
problem....HERE
SOURCE: how to fix the tension on a memory craft 8000-way too loose at the top
it's possible that the tension dial has gone bad & needs to be replaced
at a sewing machine repair shop
