Sansui VRDVD4005 DVD Player/VCR Logo
Kathy Cenicola Posted on Sep 19, 2015
The but does not help. every disk I load says samething even orig disk. Even put recorded on this player. Still says loading and then no disk. Any help appreciated.
1helpful
DVD recorder will not load even a new disk. After a period of loading opens the drawer. I suppose a dirty laser lens.
Before you go through all of that trouble, you might want to go pick up a Maxell DVD cleaning disk. I maintain a few old Laser disk players with DVD and find that this disk works well for cleaning the optics without taking apart the machine. This disk has a small brush that cleans the lens as it rotates and provides some images to show that the disk is reading. I would try this first as it is low cost ($6.00) and can be used over and over.
I hope this helps with your problem.
Hi have an mds-je500 minidisk player that stopped accepting disks, worked perfect one minute, says load error next each time i try to load, then says eject even though disk doesn't go all the way in....
The small limit switch for the disc in position typically goes bad on about 40% of all Sony Minidisc recorders. It is a $5 part, but will probably cost you $35 to get it installed.
Jvc gr-d395u video camcorder, move mini dv to computer
How it's supposed to work is to get a program that recognizes the camera, then the tape can be captures. Windows Movie Maker never supported it. In fact Microsoft doesn't even support it anymore. They have recommended using Pinncale Studio to work with DV cameras.
Once you install Studio, put the tape in, turn the camera on, Studio will load up.
I cant finalize my DVD recordings on my magnavox recorder.
Try this. In your SETUP options, ensure that AUTO FINALIZE and FINALIZE AT END OF TIMER are turned OFF.
Insert DVD to be finalized. Quickly press SETUP button. Be patient while DVD loads. (You will not see the "loading" bar on your TV screen. You will instead be mesmerized by the SETUP options!)
Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point. Picture quality is as good as the expensive DVD's.
2answers
Can't get past LOAD
it might need to be cleand u take the sheild off and take a q tip and lightly clean the laser
pls rank ps keep off the carpit
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
1helpful
2answers
DVD player - ERR
error in any disk i put in!!!!!!!!!
3answers
JVC DRM10 DVD Recorder Problem
This unit is showing and error message "Disc Not Recordable" with a maxell DVD-R 1-16 Speed Single Sided Recordable DVD.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
