Question about Sony Ericsson Sony Ericson XPERIA X8 E15i Android Quad Band, WiFi, GPS Unlocked
Screen used to hang or works with hard times... now ,touch doesnt stimulate the screen... remedy please...
    New Friend:
  • 4 Answers
Could be a problem with the touch monitor, or whatever it is called.
i would suggest you to take it to your nearest phone shop to get it checked. good luck!
Posted on Sep 19, 2015
SOURCE:
What tipe fo bird toys to you have in the shop
We have hanging type of bird toys,these type of toys are very interactive which helps to stimulate the mind of birds.As the birds are caged so they need some mental stimulation,so these toys are very useful.here i am listing the toys name
BirdSpot Logs N Blocks Hanging Bird Toy
BirdSpot Fun Spinning Stack Hanging Bird Toy
BirdSpot Cluster Hanging Bird Toy
Mar 29, 2015 | Birds
HTC TOUCH HANG WHEN I BOOT
Dear mate try to reset your phone hard i.e"Hard Reset",
Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default,
Release the TALK and END buttons, and then press ENTER on your device.
Jan 27, 2013 | HTC Touch P3450 Smartphone
What are visual toys? i was told to buy some for my toddler
Visual Toys are toys that use visual stimulation to help your learn things, through their visual sense. This is in contrast to toys that use touch or sound to stimulate learning and play.
colors, shapes and lighting are all examples of ways that visual toys work.
Jan 14, 2013 | Toys
HTC Pro2 stuck on Touchpro2 screen with B04 in red letters on bottom right corner. Tried soft reset no luck. What should I do
try a battery pull ........if that doesnt work do a hard reset (power button /answer and hang up button all at once) this will reset the phone back to factory settings so make sure you have a backup
May 17, 2010 | HTC Touch Pro Smartphone
HTC P3452 TOUCHPAD NOT WORKING
just reset ur mobile. Do not install unnecessry programs. There might be some program causing this.
Aug 06, 2009 | HTC Touch P3450 Smartphone
Htc stopped working it hangs on home screen
i had a hard time understanding your question- but iim guessing its a software glitch.... what i did to reset mine was redownload the telstra rom from the htc site (htc.com/au/- then go support- then in dfrop down choose htc touch hd- then click download on htc toucch hd rom upgrade asia- then choose telstra settings and download- should be like 100 odd mb.... once installed connect hd to com via active sync (make sure more then 50% battery) and open up this rom update... follow installation instructions and let it run (all automatic- only for htc touch hd tesltra bought in aus) - be aware that this will wipe all stuff on the phone (not memory card) ie calendar contacts (so backup using active sync b4 update your rom) after all this turn on your phone again and it should start up like the first time u ever turned it on ie touch calibration and time/date etc (this should fix any software glitches)
May 22, 2009 | HTC Touch HD Smartphone
Touch screen problem
pls reset ur device like this if it doesnt help then u have to get ur digitizer replaced also called touch panel
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Apr 07, 2009 | HTC Touch P3450 Smartphone
IPHONE touch screen not working
If hard resetting and restoring it doesn't work you have a broken LCD screen. There is an iPhone repair website that shows you how to replace the screen yourself, if you're out of warranty.
May 26, 2008 | Apple iPhone Smartphone
Touch screen do not respond
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
May 10, 2008 | HTC P3300 Smartphone
Touch screen not working
take the battery off for 15 seconds and try to put it back again. goodluck
Dec 22, 2007 | T-Mobile Wing™ Smartphone
Sony Ericsson Sony Ericson XPERIA X8 E15i Android Quad Band, WiFi, GPS Unlocked Logo
46 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
