I get this complaint a few times a month , what I usually find is that the circulation fan has a build up of fuzzy lint on the blades and it throws the fan out of balance (hence the noise) a soak in a warm water/soap solution usually takes care of it , disassembly is required for this , I usually charge two hours labor for this
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
your fan is possibly hitting something didyou drop it or bang into it you should have some one like a tech. to checkit out and PLease stop using it till you do this you could be damaging this unit even more than it allready is
With the unit unplugged, open the cover and check the alignment of the
fan. If the fan is stuck or rubbing against the fan cowling, adjust the
fan motor's mounting hardware so that the fan turns freely.
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
not sure which dehum yo have,but here I go! most fans are not part of the cooling system. first remove the housing where the fan is. turn the unit on and check to see if the fan is turning. if not then just wait till you hear the compressor kick in. if the compressor goes on then you do have a problem w/the fan motor and it will have to be replaced. worst comes to worst just bring it into Sears. they have techs which will let you know what the exact problem is and you can take it from there. make sure you give them the model # first,just to check if the have parts for your dehum.
