A
Anonymous Posted on Sep 18, 2015
How do you connect a proton d540 amplifier to a Marantz sr45 ?
Amp. Proton d540 to a Marantz sr45?
geekyshrink
Level 1:
  • Contributor 43 Answers
  • Posted on Oct 02, 2015
geekyshrink
Contributor
Level 1:
Answers
43
Questions
0
Helped
20871
Points
63
Why? The Marantz receiver already has an amp and the Proton is an integrated amp. But if you want to use the Proton as a preamp with the Maranyz you could remove the jumpers on the back of the Proton then connect RCA cables from the Proton's Pre Out to the Marantz's Tape In but I really don't see why.
Testimonial: "I appreciate advice. I have polk SRS speakers, and I love it loud. Thanks."
tip
Dish Network Stereo Receiver Remote Codes
This is the From the Dish Network website. http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml You can also call them for information on your set-up at : New customers call: 1.888.825.2557. Current customers call: 1-888-686-2388. CODE Aiwa Amplifiers 636, 641, 656, 687, 718, 720, 774, 775, 726 Bose Amplifiers 761 Carver Amplifiers 653 Citizen Amplifiers 709 Curtis Mathes Amplifiers 734 Denon Amplifiers 647, 674, 757, 758, 759, 760, 762 Fisher Amplifiers 653, 741 GE Amplifiers 711 Goldstar Amplifiers 677, 69 Harmon / Kardon Amplifiers 640, 672, 751 Hitachi Amplifiers 717, 754 JBL Amplifiers 640 JVC Amplifiers 637, 683, 703, 725 Kenwood Amplifiers 649, 676, 691, 726, 728, 745 Luxman Amplifiers 752 Magnavox Amplifiers 654, 705, 740 Marantz Amplifiers 651, 740, 742, 743, 764 NAD Amplifiers 739 Nakamichi Amplifiers 671, 748, 750 NEC Amplifiers 716, 739 Onkyo Amplifiers 642, 660, 662, 678 Optimus Amplifiers 648, 664, 734, 744, 749 Panasonic Amplifiers 643, 644, 652, 742, 746 Pioneer Amplifiers 658, 667, 668, 679, 702, 734 Proton Amplifiers 654, 705 Quasar Amplifiers 652, 742, 746 Radio Shack Amplifiers 744 RCA Amplifiers 635, 638, 704, 727 Sansui Amplifiers 753 Sanyo Amplifiers 741 Sharp Amplifiers 712, 713, 714, 715, 749 Sherwood Amplifiers 646, 670, 736, 738, 744 Sony Amplifiers 639, 645, 650, 687, 728, 728, 730 Soundmatters Amplifiers 763 Teac Amplifiers 684, 737 Technics Amplifiers 643, 644, 652, 742, 746 Toshiba Amplifiers 710 Yamaha Amplifiers 663, 730, 731, 732, 733, 745, 747
1helpful
Where can I get a proton impian 04 manual from
The best place to get hold of a proton service manual is to download it from the website
http://www.repairservicemanuals.com/Proton
1helpful
Proton am452
Transformers are safety parts, they should only be replaced by the manufactory's recommended parts. Contact them for a supplier.
Proton 520
As transformers are safety parts you need one recommended by the maker of the amp. So I would contact them about where to get a new transformer.
2answers
Which particle is the hightes in the following
Protons have a +1 charge. This is the same magnitude of an electron but an electron has a −1 charge. Neutrons have a 0 or no charge.
The following Wiki Article explains the process of Proton decay
Main article: Proton decay Protons are observed to be stable and their theoretical minimum half-life is 1036 years. Grand unified theories generally predict that proton decay should take place, although experiments so far have only resulted in a lower limit of 1035 years for the proton's lifetime. In other words, proton decay has never been witnessed and the experimental lower bound on the mean proton lifetime (2.1×1029 years) is put by the Sudbury Neutrino Observatory.[5]
However, protons are known to transform into neutrons through the process of electron capture. "When a high energy-proton collides with an atom, it causes the ejection of an electron from the outer layer of the atom."[6]:125 This process does not occur spontaneously but only when energy is supplied. The equation is:
1a11b43084f71df3683387ac7281c27b.png where
p is a proton, e is an electron, n is a neutron, and νe is an electron neutrino The process is reversible: neutrons can convert back to protons through beta decay, a common form of radioactive decay. In fact, a free neutron decays this way with a mean lifetime of about 15 minutes.
Standard amplifier + Bose Lifestyle 12 Acoustimass module
well u didn't include any models # for the proton or "cubes" so all I can speak too is a simple heads up lesson about amp loading , most modern integrated amps look for a 4 ohm load for its speakers , this is saying total load , so if one was to connect say two speakers (plus to plus and minus to minus) assuming the speakers are 4 ohm already this would divide down to only 2 ohms (this would heat up the amp and affect it working ) but also if the speakers are say 8 ohms each then this divides down to 4 ohms (and the amp would see two as only one ) , also wire length between speakers counts as well , assuming most speaker rated size wire is say .023 ohms per foot this would also have to be added to the total load the amp see's , there are far more technical ways of running longer wires to other rooms but this involves impedance matching transformers and the like . so I'll not discuss them
Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
 Grubhead
Grubhead
SmartAviator
SmartAviator
