Mathsoft StudyWorks! Middle School Deluxe Math 5.0 (11543) for PC Logo
A
Anonymous Posted on Sep 17, 2015
What's the meaning of media in math?
Like the mathematic defenition for median.
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Sep 17, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066231
Points
28436
  1. The median is also the number that is halfway into the set. To find themedian, the data should first be arranged in order from least to greatest. To remember the definition of a median, just think of the median of a road, which is the middlemost part of the road.
  2. The Median of a Set of Data - Math Goodies
    www.mathgoodies.com/lessons/vol8/median.html
What is the median math deffinition
middle number
To find the Median, place the numbers you are given in value order and find the middle number. Example: find the Median of {13, 23, 11, 16, 15, 10, 26}. Put them in order: {10, 11, 13, 15, 16, 23, 26} The middle number is 15, so the median is 15. (If there are two middle numbers, you average them.)
What is the mean in 6 13 14 7 5 in maths
I could give you the answer but this website explains very nicely, how to calculate each type of average. The second example they use fits your list of numbers better than the first.
Mean Median Mode and Range
What does mean median and mod mean?
in math? mode is the number that comes up most often, mean is all the numbers added then divided by the number of numbers, and median you put all the numbers in order and pick the middle one
What is mean median and mod in math
Math mean median mode
The mean is 10, the median is 9.8, and there is no mode.
The mean is 30, the median is 30, and the two modes are 30 and 31.
Mean, median, mode
You don't need the calculator for that. Sort the data in ascending order.
Mode
Find the most frequent data element (the one repeated the most) in the set. That is the mode. If you have several elements that share the same highest frequency all of them are modes.
Median
Count the number of elements in the set.
If the number of elements is ODD the median is the element that happens to hold the middle place in the ordered set.
If the number of data elements is EVEN, then there is not one middle element, but 2. Call them if you wish MIDLeft, and MIDRight
Take the values of these two elements and calculate their average.
Median_value =(MIDLeft+MIDRight)/2
That average is the value of the median.
You can imagine the median as a virtual (not really there) data element inserted between the two middle elements and having as value the average of the two middle elements
Your set would look like the following
{Min_value, ..., MIDLeft_value, Median_value, MIDRight_value, ..., Max_value}
Now, was there something about fractions?
The question is incomplete.
The mean, also called the average is defined as
mean= (sum of the data values)/(number of data elements)
Mode = the most frequent data value (the one that is most repeated)
To find the median:
  1. Order the data values in ascending order (sort them from the smallestr to the largest), and
  2. Locate the data value that is in the middle.
  3. If the number of data values id ODD (not a multiple of 2) there is only one middle element. That is the median.
  4. If the number of data elements is EVEN (multiple of 2), there is not one middle element but two.
  5. The median is the average of the two middle element values
    1. Median =( left of middle value +right of middle value)/2
    2. Imagine this median value to be inserted between the two middle elements
Example 1
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20)/9=?
Mode= most frequent value. Here it is 13 (repeated 3 times)
There are 9 values, an odd number. Middle element is the 5th ( 13.5)
Median=13.5
Example 2
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20, 25
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20 + 25)/10=?
There are 10 values, an even number. Middle element is not among the values. There are two middle elements (the 5th and the 6th) or
The value of the median is the average of the 5th and 6th elements or
Value of Median =(13.5+14)/2=?
2answers
mean: 77
median: 87
mode: none or all of them (take your choice)
range: 43
If this is homework, be sure to show your work.
Top Mathsoft Computers & Internet Experts
k24674
Kolbrun...
 Mikey
Mikey
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
