Sensor has new batteries but outdoor temp on unit is blank so appears it's not connecting.
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
SOURCE: breaker keeps getting flipped off
20kw heat should have 2 separate 60 amp circuits on number 6 wire.
SOURCE: i have this model and the outdoor temp sensor isnt
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
SOURCE: i put new batteries into both units, the indoor
Sometimes the RF frequency from the outside transmitter loses contact with the clock's frequency ( it has happened to me only twice in 6 years ), and then the outside temp will not show. Simple solution to fix this is: Take down the outside transmitter and the internally mounted clock. Remove batteries from both. Wait about 10 mts. First install batteries in the transmitter, then after about 30 seconds, install batteries in the clock. In about 5 mts, you will find the clock showing the external temp like before.
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
