LeapFrog Leap Frog Leappad Explorer Tablet Logo
Rita Kloppenburg Posted on Sep 17, 2015
Can't remember parent lock code. How can I refresh my memory?
Lupe Perez
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 04, 2017
Lupe Perez
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1823
Points
For paren lock code when asked for the 4 digits press 1 9 6 then backspace then 8 7 hope that helps
2helpful
Master password
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
2answers
Child lock on in LC-T32HV
1helpful
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Parental code not working on sansui television
Instructions
Cant remember parental code to unlock channel for AOV FL4L42W98H_V2_O1 ,TV
There should be an option in the main menu to return all settings to factory default. That may or may not reset the parental lock to either 0000 or 1234. Hope it helps.
Parental lock issue
Original reset code is 1379 as per manufacture.
Thank you:
Re
30helpful
2answers
Cant remember parental control code.
All Details Below On How To.
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Done
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
1helpful
Parental control lock
Here is the user manual, check page # 40 on how to clear the secret code.
Locked out
to over the lock the eprom needs to be taken out and resolder back that will reset the parental lock when ever you put in a code use a eamily member birth date yours or a friend birth date or a house address
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
