Take the seat off
Open tool box, at rear of seat, with key and unhook or unbolt the seat from inside tool box.
Pull lever on right or left side, up under the seat. It can also be at the rear of the seat, right or left side, again up under the seat. Lift seat off up and to the rear. Sometimes it's hooked on both sides with a rod or cable connecting both sides. These can break. Make sure both are unhooking.
Same as above only you use a key.
Remove the two bolts on either side at the rear of the seat. Pull seat to rear.
Nuts or bolts, at the rear and below seat, under the rear fender Remove bolts holding down the rear seat . Remove seat and then remove two bolts, at the rear, holding the front seat on.
Unlock lever on side of seat. Seat then pivots on two hinges to open. Can open to the right or left. Might have no lock.
Push button on side. Left side, I haven't found a push button on the right side... yet ! Can be locked or unlocked with a key.
Pull lever at front of seat, right or left side. Seat lifts up with the hinge at the rear.
Pull lever at rear of seat, right or left side. Seat lifts up with hinge at front.
Pull lever at front of seat, right or left, and whole seat comes off. Seat has pegs underneath that fit into rubber grommets on the frame.
