SOURCE: wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
SOURCE: whirlpool dishwasher du912pfgq1, timer will not advance
does sound like a timer issue, valve obviously works(fills in rinse) timer not advancing, ( sometimes can be from the timer knog hitting against he console itself, try pulling the knob out a bit, eprhaops its getting stuck.) looked up the timer 8535371 retails for about 115 bucks, dishwashers are no longer very expensive so keep that in mind while trying to repair this one
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
SOURCE: frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
