Singer Stylist 7258 Electric Sewing Machine Logo
k
kelly allen Posted on Sep 16, 2015
E7 error message. NOTHING works. Any other suggestions?
3answers
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
3helpful
2answers
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john-michael_38e8d20d2052609c
Machine in on and will not work, error code E7, does not have this code in manual, What does error code E7 mean
try these suggestion and if none of them work then you'll have to take the machine to a repair shop
change the needle and make sure the needle is for the fabric being sewed and is inserted correctly into the needle holder
rethread the machine top and bobbin and don't miss any thread guides
make sure the bobbin is not warped or damaged
make sure the bobbin is turned the right way in the bobbin case
if the bobbin is a front or side loading, make sure the bobbin case is inserted correctly into the machine
make sure the power cord and foot pedal is plugged into the machine securely
clean under the needle plate and in the bobbin area for lint
10helpful
7answers
How do I reset an E7 error message?
HAAA!!! Me, too!! I just got the same code. I actually took off all the stuff to clean it (glad I did too because after a whole week of sewing on it straight, it was hella filthy!), I still couldn't get it to work. The answer is in the Singer FAQ website (http://www.singerco.com/support/frequently-asked-questions). Your button hole lever has been bumped. It is just to the left of the the needle bar. I just pulled mine all the way down, then pushed it all the way back up. No more E7!!!! Color me happy for sure!
2helpful
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
2answers
My Singer Brilliance 6180 flashes E7 there is nothing about it in the manual
try changing the needle
try using a different bobbin
if these suggestions don't help then I suggest you take the machine to be checked
2answers
The machine was accidentally dropped. We started with an E7 error, and now an E3 error message.
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed
E3 means
The buttonhole or bar tack stitch was selected and the
start/stop button was pressed while the buttonhole lever
is raised.
(make sure buttonhole lever is in correct position)
If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears.
download manual for this model at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_cs80eus&dlid=&flang=English&type2=-1
Hope this helps
Error message
tell me what to look at to fix the problem
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
