Lawn mower will start and cut off, we put some either in it to get it started in started and shut down again, it appears to be flooded
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
SOURCE: cub cadet lawn mower won't
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
SOURCE: i need the drive belt diagram of the cub cadet
3 yrs later.
To find belt diagram, Look for a diagram sticker underneath the driver side foot rest. (faces the ground). Goodluck people.
SOURCE: RIDING LAWN MOWER STUCK IN GEAR
My Poulon riding lawn mower will not move when I put it into gear, and I found a 1 or 1.5 inch thin metal square shaped rod under my mower on the ground, could this be part of the problem
