I have a 1981 evivrude 25hp outboard motor throttle engine doesn't pick up speed till I push ******* manual choke then it speeds up and runs good if I let off choke it slows down
I have a 1981 evivrude 25hp outboard motor throttle engine doesn't pick up speed till I push hard on manual choke then it speeds up and runs good if I let off choke it slows down
It seems like you may be experiencing a short in the neutral switch of your Honda outboard motor. This issue could be causing the engine to shut down when you push the throttle past trolling speed. If you're able to manually run the engine without the shifter and it runs full tilt, this could further support the possibility of a short in the neutral switch. You may want to have the switch inspected and repaired or replaced by a qualified mechanic to solve the issue.
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
