Bobcat 863 Loader Service Manual Serial Numbers 514411001 514424999 Serial Numbers 514511001 514524999 Serial Numbers 514611001 514624999 963 Pages in pdf format 67 1 MB in zip...
The Bobcat 863 skid-steer loader typically has a vent to the fuel tank to prevent the formation of a vacuum as fuel is used. Fuel tanks in vehicles and equipment are designed with venting systems to maintain atmospheric pressure within the tank. This vent allows air to enter the tank as fuel is consumed, preventing a vacuum from forming, which could impede fuel flow to the engine.
The specific design of the venting system may vary from one machine to another, so it's essential to consult the operator's manual or contact the manufacturer for precise information regarding the venting system on your Bobcat 863. Proper ventilation is crucial to ensure a consistent fuel supply to the engine and prevent issues such as fuel starvation.
The Bobcat 863 is a skid steer loader model manufactured by Bobcat Company, a renowned manufacturer of construction equipment. The 863 model was produced from 1996 to 2003 and was part of the C-Series lineup. Here are some key details about the Bobcat 863:
Engine: The Bobcat 863 is powered by a diesel engine. The 863 was initially equipped with a Deutz BF4M1011F engine, which is a four-cylinder, turbocharged engine. Later models may have variations in engine specifications.
Operating Capacity: The operating capacity of the Bobcat 863 depends on the specific configuration and attachments used. However, it typically falls within the range of approximately 1,500 to 2,000 pounds (680 to 907 kilograms).
Hydraulic System: The 863 features a hydraulic system that powers the loader arms and attachments. It has auxiliary hydraulic ports for connecting various hydraulic-powered attachments, such as buckets, forks, grapples, and hydraulic hammers.
Controls: The 863 is equipped with joystick controls that allow the operator to maneuver the machine with precision. These controls enable the operator to manipulate the loader arms, drive functions, and auxiliary hydraulics.
Attachments: The Bobcat 863 is compatible with a wide range of attachments, making it versatile for various applications. Common attachments include buckets for general-purpose loading, forks for material handling, augers for digging, and sweepers for cleaning.
Safety Features: Like all Bobcat equipment, the 863 is designed with safety in mind. It features safety interlock systems to prevent accidental operation and rollover protection structures (ROPS) to protect the operator in the event of a tip-over.
Maintenance: Regular maintenance is essential to keep the Bobcat 863 operating efficiently. This includes routine checks of fluid levels, engine oil, hydraulic system, filters, and tire pressure.
The fuse panel on a Bobcat 863 skid steer loader is typically located in one of several places. It could be located in the cab of the machine, near the floor on the left or right side. It could also be located in the engine compartment, either on the side or on the firewall.
To check the fuse for the blower motor and windshield wipers, you will need to locate the fuse panel and then locate the specific fuse for these systems. The fuse panel should have a diagram that shows the location of each fuse and its corresponding circuit. If the fuse is blown, you can replace it with a new one of the same amperage rating.
If you are unable to locate the fuse panel or the specific fuse for the blower motor and windshield wipers, you may want to consult the operator's manual for your Bobcat 863. This should provide you with more detailed information on the location of the fuse panel and the specific fuses for these systems. Alternatively, you can also try contacting a Bobcat dealer or a qualified repair technician for assistance.
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
