The symptoms you are describing with your Samsung plasma TV are consistent with a failure of the plasma display panel or a failure of the plasma drivers that control the display Here are a few things you can try to troubleshoot the issue:
Check the connections: Make sure all the cables and connections to the TV are secure and not damaged. Loose or damaged cables can cause visual distortions on the screen.
Perform a factory reset: Sometimes a factory reset can fix issues with the TV. Refer to the TV manual for instructions on how to perform a factory reset.
Check the internal components: If you have experience working with electronics, you can try opening the TV and checking for any obvious damage or loose components. However, be aware that opening a TV can be dangerous and may void the warranty.
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
