Doro PhoneEasy 612 Black Mobile Phone - Unlocked microSDSlot, 2 MP Camera Logo
j
john albarian Posted on Sep 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot set the time when setting alarm. all other settings work.
antoniorojas
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Expert 280 Answers
  • Posted on Sep 15, 2015
antoniorojas
Expert
Level 2:
Dedicated:
Answers
280
Questions
0
Helped
69422
Points
668
Usually this cause by syncro open go to menu and resync
if still the same reconfigure to facory
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
1helpful
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
1helpful
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
How do I set the alarm? Please help! Am I supposed to do something after setting the time of the alarm? The display continues to flash the time.
To set your alarm you should be turning your Set Control (the big round button just below the Set Day button) to Alarm 1 or 2. Once you finish setting your time you should be able to turn the Set Control back to Clock and the time should stop flashing. If this does not work you may have a defective unit which you might have to take up with your retailer.
11helpful
Ozaki imini-how do u set ipod as alarm? Instructions vague,
When you set the alarm, afterwards you set the time; after setting the time, there's another clock that you can set ("T ON" it says), which is the start time for the ipod. Set this time and set it on "ON". The next timer is for the end time of the ipod (T OFF), I don't use it, but if set on ON it will switch off the ipod.
Now don't set the alarm! You set the start time for the ipod and on the left hand side there should be an [ON] indicator.
Hope this works!
34helpful
2answers
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
11helpful
4answers
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
ALARM CLOCK SETTING
I've manage to set it... press time/awake and the 1 flashes... use arrows to set the time... then press time/awake again for alarm 2.
But how do you know when it is actually set?? it did not go off this morning and i was late for work!
12helpful
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Top Doro Cell Phones Experts
NOEL
NOEL
john h
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
