Stephanie,
You can click the link below for information on resolving the printer error.
016-700 Out of Memory and 016-980 Disk Full Error http://dell.to/1EIxdpu
Thank You,
Dell-Jesse L
Dell Social Media and Communities
093-426 is a "black toner replace soon" error message. first make sure that you're using a dell-branded toner cartridge (you can order online here: www.dell.com/supplies) & you can try reseating the black toner cartridge.
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
please help with diagnosis of following error for Dell 5110CN CRUM ID -093-665 I tried everyting. I took the imaging drum out and poot it in, and notihng. This imaging drum worded before OK.
