Televison & Video Logo
G
Glenn Strother Posted on Sep 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is Mitsubishi DLP TV error code 44?
Have 2006 Mitsubishi DLP Projection TV Status light comes on shortly after turn on and stays solid red Using error code test I get 4 or 44 from the blinks. Can not find any detail of what that error code is
rostit
Level 3:
  • Mitsubishi Master 746 Answers
  • Posted on Sep 15, 2015
rostit
Mitsubishi Master
Level 3:
Answers
746
Questions
0
Helped
202239
Points
2851
That is an Open(blown)
Check for open F9A06 on the Power PCB
1helpful
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
1helpful
I have a mitsubishi 735 series dlp tv. Has red blinking status light. The error code was 4 blinks then two blinks. Do you know what is wrong with it?
That's the error indicating the lamp/ ballast fan has stopped working. You can get the Mitsubishi lamp / Ballast fan 299P321010 used in the V39 series DLP televisions. It comes with installation instructions and is available from www.tvrepairworld.com under the Mitsubishi DLP parts category.
My wd52327 turns on and than turns itself off
Thats a very common problem which means that the capacitors on the power PWB have most likely failed. You can get the repair kit which has the replacement Capacitors and step by step instructions with detailed pictures on how to do the repair . Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
3helpful
2answers
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
2answers
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
