My pug's depressed bc Mr. Skeleton is missing. We've been thru 4 and hoped 2 find more this yr. We've bought several similar toys but Mr. Skeleton is his go-to. I beg: when/where/how can I get more!
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
The problem with his toy is the motor that spins the belt to rotate the toy is only held down by 3 screws and there should be 4. I check on 2 toys and the is a manufacture defect. Once I tightened down the screws and added a 4th screw where there is a pre-drilled hole, the motor was held down securely and the toy now works. I hope they don't ship these toys missing the 4th screw on purpose
Most common problem would be it is frozen. Try turning the freezer down one number and wait 24 hrs.
for now you could try forcing hot water in the tube from either end, but it is a watery mess. ((( Get lots of towls ))) This is the fast method.
of course leaving the freezer door open to defrost, but you of coures will need to move the food.
or you can try a hair dryer but this can be frustrating as you dont know where it if frozen. and you cant leave the hair dryer on any spot too long as it will damage the plastic.
I believe you can get games for the Leapster Leapfrog at retailers like Wal-Mart, Target, and especially Toys-R-Us (who will have your greatest selection). We bought a similar console for my 3 yr old daughter and go to Toys-r-us for all the games and misc add-ons.
You could try Grasping the lugs with a vice-grip, just to get them loose enough to turn by hand, if that doesn't work, most workshops have skeleton keys that should fit the lugs and they can loosen them for you. Hope that helps!
ð XAC = ð ACB (Angle of elevation= Angle of depression)
AB = 5 Yards
BC = ?
Now Tan C= AB/BC
BC = AB/ Tan C
BC = 5 / Tan 28 Yards
BC = 5/.531709 Yards
BC = 9.403632 Yards
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
