Question about Vizio E500i-B1 50-Inch 1080p Smart LED HDTV
How do I fix black vertical line on one side of the screen seemingly caused by impact damage?
There appears to be no impact damage when the TV is turned off. Here are some pictures showing the issue: http://imgur.com/a/X55f8 We contacted Visio but they said that this was not covered under their warranty as it looks like impact damage. Any help in fixing this would be greatly appreciated.
    Master:
  • Vizio Master
  • 440 Answers
This kind of problem is not fixable, you need a new LCD panel.
Posted on Jan 15, 2018
SOURCE:
  • 87 Answers
SOURCE: vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 19, 2007
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
  • 734 Answers
SOURCE: No power on my Visio 32 flat screen
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Posted on Dec 02, 2008
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
brownline45
  • 310 Answers
SOURCE: screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Posted on Jun 20, 2010
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Panasonic TH-42PX60U 42"Plasma TV has left side of screen with no picture with large black and white vertical lines. Purchased in 2006, can it be fixed and how much?
Try disconnecting all of your source devices from the TV and see if the line still appears. If the line disappears, the issue may be caused by your source device or your cables.
Aug 09, 2013 | Televison & Video
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
Screen showing three vertical black lines
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 02, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Plasma screen" injury"
None. Once the screen is damaged, it's permanant. The repair parts will most likely cost MORE than a new TV.
Feb 02, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Open Questions:
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
