Question about Vizio E500i-B1 50-Inch 1080p Smart LED HDTV
How to fix black vertical line on LED TV that looks like it's caused by impact damage?
The TV has a vertical black line, that looks like it is caused by impact damage at the bottom. Support staff at Visio have said that this is not covered under their warranty because of the impact damage. We do not know what caused the damage. The TV looks fine when it is turned off, no signs of impact at all; it's only when the TV is turned on that the damage can be seen. I have attached some photos here. http://imgur.com/a/X55f8 Any help in fixing this would be appreciated.
SOURCE:
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
  • 734 Answers
SOURCE: No power on my Visio 32 flat screen
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Posted on Dec 02, 2008
Mas Baz
  • 177 Answers
SOURCE: LCD tv Vizio 42 inch has vertical colored lines
hello imvega7, as i know, 42 inch is a plasma display TV.
Refer to your image, and my experience that symptomp because of connection between buffer PCB and panel. Some cases, dirty conection may cause this symptomp.
Un plug power cord, open rear cover, fine pcb on upper or lower panel.
unplug flat cables from pcb buffer, clean soket using a brush. And also clean flat cables using celaner or alcohol.
Wait untill that conection dry. reassembly and try it.
i hope that help you.
Posted on Mar 15, 2011
Testimonial: "Very detailed."
  • 8457 Answers
SOURCE: Visio Strange Color/Pixel Problem As of
The tv main Tuner signal board it is the causes and the problems.The board it is dying and shorting out.U have some mechanicals skills,like take things aparts and putting it back togetther again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal board for the replacement.
Posted on Jul 14, 2011
gopakumarg43
  • 76140 Answers
SOURCE: How do I fix the vertical green lines on my Vizio 26
Check and replace T'Con board.
Posted on Jun 10, 2012
I have an LG 47GA6400 TV. I have 2 large vertical lines on the screen. I need help identifying what is causing the lines. Could it be the t-con board?
PEOPLE, YOU MAY DON'T NEED TO BUY T-CON CARDS OR ANYTHING LIKE THAT, THE FIXING FOR THIS PROBLEM COULD BE VERY EASY, MOST OF THE TIMES IS A FAULTY CONTACT IN THE RIBBON CONNECTOR THAT FEEDS THE LED SCREEN AND THIS FIX APPLY FOR SO MANY BRANDS, MODELS, OR SIZES OUT THERE, GOOD LUCK!. DISCLAIMER: THIS VIDEO IS FOR REFERENCE ONLY AND I WON'T BE RESPONSIBLE FOR ANY FURTHER DAMAGES OR INJURIES YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!. THANKS FOR LOOKING.
SHOW MORE
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55 MODEL LG 55LX6500
Jan 29, 2018 | LG Televison & Video
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
There is a yellow vertical line on the left side of my screen, how do I fix it?
Vertical lines on the screen are caused by a failed screen, not any electrical components inside the TV
Feb 17, 2016 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
What should i do,model number below has vertical lines on half of the screen, any suggestions?
If they are blurry lines, likely you have a problem with heat damaging the diffuser plate behind the LCD. Unfortunately, there is no fix to this other than to replace the screen, which is as much as the same TV used. It's usually caused from the vents in the back of the tv getting clogged with dust/debris/smoke and the power inverter overheats. It causes the screen to develop a line on one side of the screen, then it starts to look like the screen was washed with something and you get black streaks running from the top which usually is accompanied by a darkened blurry "cloud".
May 08, 2014 | Seiki 32" LED TV - SE321FB
My LG 50'' has Black vertical lines after only 3 weeks
The Vertical Amplifier has failed in some section, or a faulty power supply to that section, it is almost impossible to tell, until one looks at the set. a Symptom, like this can, and does have a number of "Causes". This must be fixed first,and then any damage caused, must be repaired.
Apr 04, 2010 | Televison & Video
Plasma screen" injury"
None. Once the screen is damaged, it's permanant. The repair parts will most likely cost MORE than a new TV.
Feb 02, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
35 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
