Danby DWC283BLS Wine Cooler Logo
Sheila Nelson Posted on Mar 07, 2018
Changing temp controls
Power went out so temp setting went back warmest setting. When we push the buttons to lower temps, they flash but go back to the higher temp settings. We can find the manual so how do you change the temps to stay at the temperatures you select???? Thank you to anyone who can help.
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Dec 26, 2007
SOURCE: Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Anonymous
  • 4 Answers
  • Posted on Aug 07, 2009
SOURCE: danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Anonymous
  • Posted on Sep 12, 2009
SOURCE: Digital Temp Controller Problems
I unscrewed the top plate, removed 2 screws on circuit board for display, removed the ribbon tape and pulled off the front digital display(stuck on with sticky tape) and then replaced the same display unit and the buttons are working now... going to search online for new display.
Anonymous
  • Posted on Oct 13, 2009
SOURCE: Accidental defrost
I did the same thing. I know it's a little late now but for anyone that does this again here's what to do. There's a thermostat in your actual freezer you might not be able to see it, because it might be covered in ice. It looks like a tiny tube, To stop the defrosting all you have to do is warm up the thermostat either pressing a hot towel agaisnt it or meltling the ice with a dryer (but be careful)! After a minute or so the red button should pop out again and the refrigerator will start humming again. Unplugging the refrigerator will not reset anything and don't try to pop the red button out of your own!
Anonymous
  • 1891 Answers
  • Posted on Aug 10, 2010
SOURCE: Set temp to 42 and
sounds like the compressor is not running . ck the connectons at compressor and listen for a click in the cold control as it may be bad .. / noises like clicking at compresor . may be the relay that starts it .. mm
How to rest temp controls after a power surge on a samsung rt18m6213ww/aa
First things to try:
1. Unplug the fridge and move it away from the wall. 2. Inspect the power cord for damage. Replace the power cord if it is damaged. 3. Plug the fridge back into the wall outlet. 4. Set the temperature control to the desired level. 5. Push the "Reset" button, located near the temperature control panel, to reset the temp control settings. The Reset button is usually red in color. 6. Move the fridge back to its original position.
Setting date and time on a Hitachi RAR-3U3 split system controller
hi
Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
On my samsung refrigerator is the higher number coldestor warmest
If you push the freezer temp button the display on the freezer side will show set temp for freezer and after a few seconds it shows actual temp. Same thing if you push fridge side.
The temp setting is on 4 for both the freezer and refrig. Which way do we set the temp controls to warm up the temp? Is the lower setting warm or cold?
Good day,
The higher the number the colder the temp. 1 being the warmest.
It takes 12 to 24 hours to realize a new setting's effect. Go slow.
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
1helpful
2answers
With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
1helpful
2answers
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Top Danby Furniture Experts
ZJ Limited
ZJ Limited
Are you a Danby Furniture Expert? Answer questions, earn points and help others
