I have a laptop and I got a message my computer was shutting down to protect itself.It shut down and won't come back on,just a black screen,power button comes on?
Have tried f8 to get it to come up in safe mode,no good.Have also held in on power button but nothing.
Your tv is shutting itself back down because it is protecting itself from further damage from an internal issue. U might want to check the power supply for proper operation since is a common source of hassles.
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Base from the description of your problem , this seems to be a motherboard failure already. The blacking out of your screen before this problem started is a sign of something on the motherboard is already failing.
Now since the computer will just power ON and automatically shut itself down is definitely an implication of motherboard and processor failure it can be due to overheating problem, so if you want to continue using this laptop a motherboard replacement is needed, you can take replace it by yourself if you have any experience doing those kind of things but if not better take it to a repair shop or better yet do a upgrade and get a new laptop then.
Laptop turns off suddenly? Computers may not be smarter than people, but
if
they’re designed properly, they will shut themselves down before
overheating to the extent that they do themselves damage.
If the
smart
person keeps turning the notebook back on and figures out a way to foil
the protection, the laptop is probably doomed.
Once a laptop
shuts down
for thermal event protection, it may refuse to power back up for a fixed
period of time, five or ten minutes, or it may begin to boot and shut
down immediately as soon as it boots to the point that it can figure out
that its too hot.
The over-temperature protection is generally a
BIOS
rather than an operating system function, so one sign of an overheated
laptop is one that shuts itself down while you’re using it and then
refuses to boot as far as the operating system unless you leave it alone
for an hour or so to cool down.
Unless you’ve been working in a
very
unfriendly environment, high temperatures, direct sunlight, etc, you
should take even a single overheating shutdown as a warning to back up
your data at the first opportunity and to give the cooling system a
serious cleaning.
That actually is a flaw in the Sansung phone itself, its something in the manufacturing. When getting large messages or multimedia messages the Samsung will power itself on and off. Had the same problem with Samsung.
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed
properly, they will shut themselves down before overheating to the
extent that they do themselves damage. If the smart person keeps
turning the notebook back on and figures out a way to foil the
Once a laptop shuts down for
out that its too hot.
BIOS rather than an operating system function, so one sign of an
overheated laptop is one that shuts itself down while you’re using it
and then refuses to boot as far as the operating system unless you
leave it alone for an hour or so to cool down.
Unless you’ve been
working in a very unfriendly environment, high temperatures, direct
sunlight, etc, you should take even a single overheating shutdown as a
warning to back up your data at the first opportunity and to give the
cooling system a serious cleaning.
If the laptop shutdown maybe it cause overheating. Laptop shuts down? Computers may not be smarter than people, but if
overheating to the extent that they do themselves damage. If the smart
the protection, the laptop is probably doomed. Once a laptop shuts down
fixed period of time, five or ten minutes, or it may begin to boot and
shut down immediately as soon as it boots to the point that it can
figure out that its too hot. The over-temperature protection is
generally a BIOS rather than an operating system function, so one sign
of an overheated laptop is one that shuts itself down while you’re
using it and then refuses to boot as far as the operating system unless
you leave it alone for an hour or so to cool down. Unless you’ve been
does your computer have a webcam? if it does, the computer is restarting itself because it identifies two conflicting cameras - one from your computer, the other from your iphone. what you can do is either 1)update your camera drive, 2)update your computer drive or 3)use a computer that does not have a webcam connected to it. hope this helped!
also, if you're using windows vista, this link will help you: http://support.apple.com/kb/TS2280?viewlocale=en_US
