Toshiba 24AF42 24" TV Logo
K
Katie Holmes Posted on Sep 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set up my tv with my sony vcr
SLV-679HF VCR player with Toshiba 24AF42 tv. was set up and pushed the channel button and now won't show any picture or sound! vcr is working, tried on different channels, set tracking channel on vcr to match tv channel, just getting grey fuzzies on tv. tried turning on and off, unplugging and replugging.
  • Katie Holmes
    Katie Holmes Sep 14, 2015
    figured it out! just had to mess with the input button :)
  • Jaime Hernandez Sep 14, 2015
    Thank you for letting us know that it works now
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Sep 14, 2015
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783350
Points
6681
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
WHAT E32505.. VCR SLV 690HF
https://www.cnet.com/products/sony-slv-679hf-vcr-vhs/
5answers
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
2answers
TV Channel setting via Sony DVD/VCR combo
Hi Chis... I will look for a manal for you and get right back :)
robotek
How can I receive and record cable channels on my Sony SLV 750 vcr? The tuner only displays channels 1-99 on the vcr. Thank you.
I will be assuming you have analog cable TV service, no cable box. If you have a cable box, the instructions would be different.
There are many steps to properly setup your Sony VCR and they should ALL be setup to correctly record channels, however just to cover your question here....
Press MENU on the remote control for the VCR and you should see on your TV screen, the main menu options. Select TUNER PRESET. Press OK. Set Antenna/Cable to CABLE. Next Select AUTO-PRESET. Available channels will be scanned. This may take a few mins. so be patient. Channels could go up to 125. This should make available cable channels ready to record/view.
You can ADD or Delete a specific channel also if one is missed or undesired by selecting MANUAL SET.
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
1helpful
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
