Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board  13 Logo
G
George Posted on Sep 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn on treadmill, display lights go and than immediately go out
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Sep 14, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063775
Points
28436
Arduino + U-MC 2100-WA Treadmill Motor Controller ...
? 5:16
www.youtube.com/watch?v=rAZ8FCzOuxE
May 27, 2013 - Uploaded by Grant Brown House came with a broken treadmill, but the motor/controllerwas still ... pin 13 referenced in the code is the arduino pin, not one on the board.
1helpful
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
How to reset oil light on yowza treadmill?
Oil Light Reset Procedure
Turn the treadmill off using the safety key.
While treadmill is off, press and hold Speed Up & Speed Down for 3 seconds, continue to hold them while you turn the safety key to the on position.
After the treadmill display turns on you will see a 1 in the bottom corner, you can release the Speed Up & Down buttons.
Use Incline Up to change the 1 to a 3.
Press Start to enter menu.
Press Speed Down to reset distance counter, press enter to save, press enter again to exit menu.
Machine shuts off- says LS
follow this steps and fix it. God bless you
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
1helpful
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
1helpful
I have no display lights on my 665 E. I don't have a manual as this treadmill is used.
rthorne330-
I may be able to help. So the display does not light up...does the unit otherwise work? Does the belt turn, can you adjust the speed, etc?
The manual is available online at the following link: Link
Regards,
DIYpro
I have a Lifefitness Treadmill model TR 9100, serial 381872. When I turn on the power switch, the treadmill does nothing. Nothing appears or lights up on the front console. I removed the motor cover and...
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
2answers
A2350 doesn't start, just cycles through programs on display
This is just the store display mode it comes with - check the manual, it should tell you how to easily turn off the store display mode.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
