Cars & Trucks Logo
Ed Keeler Posted on Sep 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1994. Why is there no power on fuse that controls cluster lights, a/c and heater controls, cigar lighter light and ash receiver light, radio lamps and overdrive?
Switch lamps but everthing still works like it should
paulmacintyre
Level 3:
  • Dodge Master 3,218 Answers
  • Posted on Sep 13, 2015
paulmacintyre
Dodge Master
Level 3:
Answers
3218
Questions
0
Helped
968171
Points
11418
Looks as if it is a 4amp fuse and power comes from the headlight switch. Do park lights work? Looks as if 20amp fuse to headlight switch controls park lights and possibly power supply through switch to 4amp fuse. This diagram is for a 6cyl and should be the same as an 8cyl. Hope it helps
1994. Why is there no power on fuse that controls  - 25863038-h4wofp5wcg4kwjnch0rj2odk-1-0.gif
Testimonial: "yes the parking lights comes on, in fact everything comes on like it should, but my gauges do alot of bouncing back and fourth"
3answers
1994 Dodge Dakota fuse for horn & cigarette lighter
f you look on the inside of the fuse cover, it is probably labelled Auxiliary.
Where is my ign fuse located on car
Below dash instrument panel, R16 ignition relay
98 Ford Contour SE Fuse Box Map
Fuse Panel Layout Diagram Parts: passenger side air bag, heater blower, interior lighting, heater blower motor, parking lamp, interior lighting, electric mirror, clock, wiper motor, ignition, reverse voltage protection, rear window defrost, engine management system, instrument panel illumination, radio, wiper motor, power windows, ABS module, backup lamp, brake lamp, door lock, main light, cigar lighter, electric seats,
link below should be the same as yours, press the helpful button
http://www.autofuseboxdiagram.com/1342-98-ford-contour-se-fuse-box-diagram
My 1983 Monte Carlos fuse box labels are worn off. I need to know if I got all the fuses I need or if am missing fuses
1. 5 Amp (Tan) - Instrument panel lights and lights-on reminder
2. 20 Amp (Yellow) - Choke heater
3. 30 Amp - Circuit Breaker. Power windows and sunroof
4. 10 Amp (Red) - Electronic control module
5. 25 Amp (White) - Heater and air conditioning
6. 20 Amp (Yellow - Stop and hazard lights
7. 25 Amp (white) - Windshield wipers
8. 10 Amp (Red) - Radio and cruise control
9. 30 Amp - Circuit Breaker. - Power door locks, seats and rear window defogger
10. 20 Amp (Yellow) - Courtesy lights, key warning chime, power antenna, horns, cigar lighter and clock
11. 20 Amp (Yellow) - Turn signals and back-up lamps
12. 20 Amp (Yellow) - Parking, side marker, license plate and tail lamps
13. 10 Amp (Red) - Warning lamps and buzzers, trunk release, torque converter clutch and vehicleicon1.png
speed sensor
2helpful
Words on fuse box diagram faded. whats the appropriate fuses?
Please review this article: Where's The Fuse?
speed sensor
14. Not Used
4helpful
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
4helpful
2answers
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
I have no cigar lighter hahe changed cigar lighter
Take wires out of cigaret lighter , then replace fuse , if fuse stays ok without cigaret lighter connected then something shortning lighter inside.
34helpful
I need a fuse box diagram for my 95 dodge dakota
Fuse 1: 30A, Green; A/C Heater Motor Fuse 2: 30A Silver (Circuit Breaker); Power Windows Fuse 3: 15A Light Blue; Overhead Consule, Day/Night Mirror, Reverse Lamps Fuse 4: 5A Tan; ABS (There is not on in the picture) Fuse 5: 20A Yellow; Power Door Locks Fuse 6: 20A Yellow; Horn Relay, Instrument Cluster, Radio Choke Relay (on Premium audio system) Fuse 7: 10A Red; Buzzer Module, Stop Lamps Fuse 8: 20A Yellow; Headlamp Switch Fuse 9: 15A Light Blue; Cigar Lighter Fuse 10: 20A Yellow; Windshield Wiper Fuse 11: 20A Yellow; Turn Signal Fuse 12: 10A Red; Radio Fuse 13: 4A Pink; Recives power from Fuse 8 to power instrument lights (such as the cigar ligher lighting, ash tray light, dash lights, radio lights, etc.) Fuse 14: 15A Light Blue; Instrument Cluster Fuse 15: EMPTY Fuse 16: 5A Tan; Buzzer Module, 4WD Indicator Lamp, Tranny O/D Switch, Tranny Oil Temperature Sensor Fuse 17: EMPTY Fuse 18: EMPTY Fuse 19: EMPTY Fuse 20: 25A Natural; Park Lamp Relay, Off Road Lamp Switch (There is not one in the picture, I believe this is only on vehicles with fog lamps)
NOTE 1: Fuse 3 and Fuse 14 provide power for the Airbag Control Module Cavities 2, and 1, respectivly. NOTE 2: Fuse 4, Fuse 7 and Fuse 11 provide power for the Controller ABS Brake Cavities 7 and 12, 9, and 3, respectivly.
Under Fuse 4, 8, and 12 is the Buzzer Module (Black rectangle in the picture) Under Fuse 16 is the Hazard Flasher (Silver circle in the picture) Under Fuse 20 is the Horn Relay (White plastic looking in the picture) To the side of Fuse 17 and 18 is the ABS Warning Lamp Relay (Open cavity in the picture) To the side of Fuse 19 and 20 is the Turn Signal Flasher (Blue circle in the picture) Between the Turn Signal Flasher and the Horn Relay is the Time Delay Relaly (the other Silver Circle in the corner, in the picture
6helpful
I need a printable image of fuse block / 97 ford windstar
your owner manual sould have fuse chart. Some fuses/ekays in enine compartment. Some in car on left side of instrument panel
in car
Fuse Amps Circuits Protected 1 10 Power Mirrors, Anti-Theft Warning Light, Diagnostic Connector 2 5 Generic Electronic Module, Start Interrupt Relay Coil 3 5 Radio Illumination, Remote Radio Illumination, Electronic Instrument Cluster, Electronic Instrument Cluster PRNDL Illumination, Electronic Instrument Cluster Switch Module, Analog Cluster Illumination, Instrument Illumination 4 — Not Used 5 — Not Used 6 15 Rear Quarter Windows (LH and RH) 7 15 High Mounted Stoplamp, Brake Shift Interlock 8 25 Subwoofer, JBL Amplifier 9 10 Park and Turn Lamps, Side Marker Lamps, License Lamps, Stop Lamps 10 2 High Beam Indicator Electronic Cluster 11 15 Park Lamps 12 10 Remote Radio, Auxiliary Warning Lamp Module, Remote Keyless Entry (RKE) Module, Anti-Theft Controller Module, Radio Illumination 13 15 Radio, CD Disc Changer 14 5 Electronic Chromatic Mirror, Analog Cluster Indicator Lamps, Air Bag Module 15 — Not Used 16 15 Horns, Horn Relay Coil 17 15 Fog Lamps 18 25 Front Wiper Motor, Front Washer Pump, Wiper/Washer Relays 19 10 Generic Electronic Module (Pin 57), Electronic Instrument Cluster 20 25 Integrated Relay Control Module, Ignition Coil 21 10 Air Bag Module, Rear Window Defrost Relay, A/C Clutch, Temp Blend Door Actuator, Brake Shift Interlock 22 20 Rear Cigar Lighter, Power Plug 23 15 Multi-Function Switch 24 20 Rear Wiper Motor, Rear Washer Pump 25 10 Turn Signal Lamps, Instrument Cluster Turn Indicator 26 15 LH Aero Headlamp, Left and Right Trailer Stop/Turn/Hazard 27 15 Hazard Warning Lamps, Instrument Cluster Turn Indicator 28 15 Instrument Panel Cigar Lighter 29 15 Battery Saver Relay, Interior Lamp Control Relay, Interior Lamps, RH and LH Keyhole Lamps 30 25 Backup Lamps, Electronic Cluster 31 10 Rear Air Suspension 32 15 RH Aero Headlamp, Trailer Park Lamps 33 15 Anti-Lock Brake (ABS) Relay, Anti-Lock Brake (ABS) Module, Daytime Running Lamp (DRL) Module 34 30 One Touch Relay, LH Window Motor 35 15 Anti-Theft Controller Module 36 30 A/C Mode Switch 37 20 Door Lock Actuators, Memory Door Lock Relay 38 15 Heated Mirrors (LH and RH) 39 30 Auxiliary Blower Motor, Ref. Valve Solenoid 40 30 Window Motor (RH) 41 5 Autolamp Relay Coils, Autolamp Sensor 42 — — 43 — — 44 — —
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
