Hi Eddie,
See if this link helps:
http://www.ereplacementparts.com/yard-man-25a258l401-2003-trimmer-parts-c-27581_27582_27587.html
Good Luck!
Jim
SOURCE: yard man ym-25 lawn trimmer quits running.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You
will need to disassemble the carburetor and spray with carb.cleaner.
Make sure the small screen is free of debris. (Should be able to see
daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
Jim
Testimonial: "You were 100% correct. The screen was plugged. Thank you."
SOURCE: REPLACE A BELT ON THE YARD MAN EDGER
Hi try this site just look up your model and it will show you a parts list in exploded view.
SOURCE: OUR CHURCH HAS AN 18" YARD MACHINE STRING TRIMMER
The trimmer line is pretty easy to attach. The trimmer line comes in pre-cut lengths, and is threaded in two places through loops on the spindle. (Two pre-cut trimmer lines are needed.)
