After click on copy it will be requesting me to load paper even though the papers were already loaded
SOURCE: LOAD PAPER
dutchy, Don't let it run out of paper...enough wiseguy...Check your printer settings. This site should be able to point you in the right direction. http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=238&modelid=10444 Good Luck, Tim
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
SOURCE: Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
SOURCE: printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
