I ask a Mecanic to change the starter and now RADIO, Light on top and door wont work, Little light on hash tree is dead, Buzzer went key is in ignition is not working as weel and the electric door not working as well !! ANYONE Would know, why after changing starter everything are dead ? Plus now it take 5 LONG sec for the engine to actually start I turn the key and engin turn give power not like the battery is dead but more like the starter take time to start the engine, put it seem slow and engine start after 5 long sec Before I turn the key and bang it start quick, ANY GUY CAN HELP OUT ? If you can give me a hint ! We check all the fuse and they all look ok ?
I would say check all the fuses again, both in passenger compartment and under the hood. plus, the mechanic should be responsible for this issue. it also sounds like you battery is not fully charged. i would also suspect, the starter was changed without disconnecting the battery and something was shorted as he installed the starter. good luck
