It sounds like there may be a few potential issues that could be causing the resistance you are experiencing:
Incorrect installation of the slow speed gear or key - If the slow speed gear or key were installed incorrectly, this could cause increased resistance in certain gears. Double-check the installation of these components to ensure they are properly oriented and positioned.
Stuck gears - If the gears and key are stuck on the drive shaft, this could cause increased resistance. Try removing the gears and key again, and make sure they are clean and free of any debris before re-installing them.
Improper alignment of the gears - If the gears are not properly aligned, this could cause increased resistance. Check to make sure the gears are properly seated and aligned with each other.
Damage to the worm wheel - The freshly chewed up center of the worm wheel could be causing increased resistance. Consider replacing the worm wheel if it appears to be damaged.
Overall, it may be helpful to consult the Hobart service manual for your specific model to ensure all components are installed correctly and to troubleshoot any additional issues that may be causing the resistance.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
It is not a good idea to modify anything in the unit to make part(s)
designed for another model fit. The KT and KP models have different
part numbers for the motor. I still don't understand why do you have to
change motor in the first place, just because the Worm Gear Follower
has to be replaced. Something is telling me, you have just purchased
the wrong part (Follower). The KT2651x is similar to the KP26xxx
latest models and the Worm Gear does not come with the Follower.
(i.e. they are 2 different distinct parts)
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
the internet. search for "kitchenaid worm gear".
When you replace the worm gear, you should be able to see if you need more grease. This will have been the "oil" you saw escaping.
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
