Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
D
David Shackleford Posted on Sep 10, 2015
I have replaced the diode, magnetron and the control board and it still does not heat.
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Have power but no heat
common issues that cause this:
Bad Diode that many units use.
Bad inverter circuit board that controls and is connected to the Magnetron.
Bad Magnetron that does the cooking.
12_14_2012_5_19_39_pm.jpgtypical diode used
12_14_2012_5_20_16_pm.jpgTypical Magnetron
Microwave runs but does not heat
Possible Diode most use
Possible Inverter board that controls and fires the Magnetron
Possible bad Magnetron.
12_13_2012_8_48_58_pm.jpgTypical microwave diode.
12_13_2012_8_49_38_pm.jpg typical Magnetron
1helpful
My microwave oven quit heating . No error message or any other problem. all buttons work fine just no heat
If it has a turntable that does move it usually means one of three things bad:
1. A diode many use for power purposes for the heating.
2. A circuit board called an inverter that powers the heating and controls the Magnetron.
3. A Magnetron which does the actual heating.
12_11_2012_3_08_28_pm.jpgTypical diode which cannot read shorted or open across.
12_11_2012_3_10_09_pm.jpgTypical Magnetron which usually cannot be tested by normal means but has to be replaced to know if good or bad.
1helpful
Not heating
Usually one of three things and not in any order:
The diode commonly used in most microwaves= it cannot be shorted and work.
The inverter board which powers the Magnetron.
The magnetron itself which does the work and can only be tested for sure by replacing.
12_12_2012_1_10_05_am.jpgtypical Microwave diode.
12_12_2012_1_10_45_am.jpgtypical Magnetron
1helpful
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
2helpful
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
1helpful
Maytag microwave problem everything seemingly works but does not heat. Help
Emerson mw8991sb is not heating up
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
