SOURCE: Power Led Flashing red 6 times....
the thermocoupler fuse is what it is called by the way. i also saw that it could be the "power board" which could or could not be synonymous with the thermocoupler. anyway, again it is a common problem with these models. Scott Jackson, MS
SOURCE: when i press the power button on the front it
Hardware problem for sure.
They're not easy to fix. I'd recommend calling Sony
1-800-345-SONY
SOURCE: TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
