Question about Freezers
What does the temp display on the freezer tell me?
I have set the freezer temperature to 0 degrees F using the up/down arrows. When I push the Temp Display button on the freezer front, it shows a temp of 23 degrees F. So is this the internal temp? Will the temp lower to the 0 degrees I set?
  • 2,760 Answers
Unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Posted on Sep 10, 2015
SOURCE:
How lpw of a temp. Can this freezer reach..and and if only 0 degree could the thermostat temp control be changed out so it could reach les than 0 temperatures like negative 20 or so?
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Sep 18, 2011 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Freezer temperature came up to about 35 degrees. We took all food out. Temperature is holding around 32 to 35 degrees. This is on the colder setting that used to read around 0 degrees. What do I need to...
If there is frost on the back of the freezer then there is a defrost problem. If no Frost then i would advise you to take the back off the freezer and see if there is any frost on the coils. If no then the compressor is insuffecient and or no freon.
Mar 14, 2011 | Freezers
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
What is normal temperature for fridge what is normal temp for freeer
for fridge it is 12 degree celcious and for freezer it is 0 degree
Sep 11, 2009 | Freezers
Freezer temperature went from 0 to 20 degrees farenheit and holding.I had the digital readout, alarm, and temp. setting go out 1 year ago and replaced with inside temp. guage. I have a warrnty on the...
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 25, 2017 | Kenmore Freezers
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
Jun 24, 2017 | GE Freezers
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
157 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
