Food Mixers Logo
Jodie Elliott Posted on Sep 10, 2015
A701a. How can I replace lost blue cover where blender attaches?
Hi, I'm from Malaysia.I have a Kenwood Chef model A701A.While creaming cheese the power whisk does not rotate.Could you please help to overcome this problem.thank you.
Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
There is also a belt from the motor to the gearbox and the belt may have broken or come off.
The belt can be found on Ebay here:
http://cgi.ebay.com.sg/KENWOOD-CHEF-MAJOR-GENUINE-TOOTHED-RUBBER-BELT-197944-/200565225066?pt=UK_Home_Garden_Kitchen_Mixers&hash=item2eb29e766a
Thanks for choosing FixYa,
Kelly
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
11helpful
22answers
Kenwood A701a service manual
Hi I'd really appreciate a service manual please?!
3helpful
Kenwood chef A701A mixer not working but blender does
could be one of three things
1) the belt is broken to the main gearbox (fairly easy to replace if you can get one)
2) a gear has slipped or broken which means none of the front end will operate.(I have this problem and cannot get the gear body to open)
3) If the top and front worms are turning then the problem is with the planetary gear which again is fairly easy to replace
Bill N
1helpful
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Can opener
Hello .
if you want assemble can opener to your A701A
the model is : A778
please visit our web site Kenwood Chef Restore in the section download, you find the compatibility of the attachment to download.
also Download in the same section the instruction book for A701A models and there explain how you fit the can opener and another's attachments
regards
4helpful
Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Kenwood chef
It could be a broken drive belt, this is usually located under the top cover. You may need to remove a couple of screws to get at it. Don't forget to unplug the mixer before trying this.
Mar 18, 2008 • Food Mixers
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
