I assume that you haven't cleaned up the oven for so long.
Try clean up the dirts tray put under the main machine if it has one.
If it is a steam oven it should have self clean function.
I'm assuming you have a gas oven.
You may have a sensitivity to combustion by products like CO2 (carbon dioxide) or CO (Carbon Monoxide) that are produced when the oven operates or there could be a malfunction with the oven. You didn't specify a make or model, but it's important to keep the oven clean as well.
In either case, crack a nearby window when using the oven if you have one and see if that helps. Some newer homes are so tight that the oven may not have enough fresh air and the by product gasses are building up.
If the condition persists, you may want to call a repair service to check the appliance. Also, all homes should be equipped with combination smoke and carbon monoxide detectors. The CO detector will alarm if the gas concentration starts to build up, signaling a potentially dangerous situation.
