How do i type roman figures thu my keyboard - Computers & Internet
    Master:
  • 195 Answers
SOURCE:
Tip
How To Remove and Install a MAP Sensor for Your 1988 Dodge Aries
REMOVAL & INSTALLATION
Chrysler Electronic Fuel Injection (EFI), Multi-point Fuel Injection (MFI) and Eagle Throttle Body Fuel Injection (TBI) Systems
  1. Disconnect the negative battery cable.
  2. Unplug the electrical connector from the sensor.
  3. If so equipped, disconnect the vacuum hose from the sensor.
  4. Remove the MAP sensor mounting fasteners.
  5. Remove the sensor from the vehicle.
To install:
  1. Install the MAP sensor into its position and secure in place with the mounting screws. Tighten the screws until snug.
  2. Connect the vacuum hose, if so equipped.
  3. Plug the electrical connector back into the sensor. Make certain that the connector is clean and snug fitting.
  4. Connect the battery cable.
on Nov 22, 2011 | 1988 Dodge Aries
I have an asus eee pc 4g (linux) and i want to change finnish languge to english. please help....
Changing Languages:
  1. Click on start
  2. Control panel
  3. Regional and language options, there you have the option to change the language to pretty much any language that you want
Sep 26, 2011 | ASUS Eee 4G Notebook
Roman numeral for 598,987,567,345. pls.
Hi
Here are the conversions. Is this for your exams?
598 - DXCVIII
987 - CMLXXXVII
567 - DLXVII
345 - CCCXLV
Regards
Jul 19, 2011 | Roman Toys
How do i type roman numbers on a computer?
I think you are talking about bullet points, right? You have to start a list and right click on the number. Then go to Bullets and Numbering and select the type of Roman numerals you like (lower or upper case).
Nov 03, 2010 | Computers & Internet
? Key keeps changing function
The question mark key (?) normally doesn't change function, unless you've loaded foreign language support and changed the keyboard layout setting in your operating system. If you're in the U.S. and using U.S.-English applications, you should specify that you're using a U.S. 102 or 104-key layout, or whatever your keyboard actually is, and make sure that you're not inadvertently running a keyboard support driver for a non-Roman character set.
Aug 09, 2009 | Acer NSK8458AN Keyboard
I want a diagram with all key functions explained for asus keyboard.
Sorry us techs cant even get this from the manufacture. If you would like to take a good pic of your keyboard I can go over it and label items for ya or do a walk thu.
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Experienced techs waiting to help you with your needs.
Jun 24, 2009 | ASUS 90-A4C1K1000 Keyboard
Its typing numbers when pressed letters
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 10, 2009 | HP 386209-001 Keyboard
Locked keyboard buttons
  4. Click Add .
Jun 02, 2009 | HP DC170B Keyboard
My half of the keypad(Right Side) not working
  4. Click Add .
  8. If required reinstall the drivers
Apr 15, 2009 | Computers & Internet
Computers & Internet Logo
217 people viewed this question
Alun Cox
