Cars & Trucks Logo
A
Anonymous Posted on Sep 08, 2015
Replaced fuel pump on golf cart, not getting full power to move cart forward or back
Won't pump enough fuel to fire up the golf cart to full power. Is there something else I can try? Even spraying ether into the carb won't get it to fire up all the way
wadingriver
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Cars & Trucks Master 2,248 Answers
  • Posted on Sep 08, 2015
wadingriver
Level 3:
Renaissance:
Answers
2248
Questions
7
Helped
382397
Points
5417
If the Cart sat for months, I would bet the ethanol gas gummed up your carb. Ethanol gas.... What are our politicians thinking????
Why dosent my 1989 ezgo golf cart will not start it has spark and gas change the spark plug has good spark butwont even try to start thank you good compression around 80 psi
As long as you have fire, fuel and air to the engine it should run. Can you spray fuel into the carb and get it to start. May be a bad fuel pump.
Check the exhaust and make sure it is not plugged cause if so then the fuel will not get pulled into the cyl due to putting to much back pressure on the cylinder.
I have a 1990 ez go golf cart won't fire replaced Battery solenoid and coil what else could it be?
Spark plug, fuel filter, fuel pump, plugged air filter, Is there battery power getting to the coil while it's cranking? The ignition switch could be acting up.
My club car gas golf cart was running good then al the sudden wont go over idle speed
Perhaps it's a stuck carburetor float valve, bad fuel pump (if it has one) or clogged fuel filter.
I have a golfcart G16A and the motor wont move
Yes, the G16A is a Yamaha, petrol powered engine.
Check the following:
Spark plugs, leads and coil
Fuel filter, air filter, and fuel pump.
Also check your battery voltage.
Golf cart will not start
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
1helpful
Fuel Delivery?
did you check the old pump?
were you sure that there was power to it?
i have run into this many times that people replace the pump without checking power?
so do you have power to the pump?
i have had a bad wiring harness or bad connection do this same thing. and when the fuel pump is removed the wiring gets moved around and make a connection again but not for long.
so chek power as close to the pump as you can
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
