We are installing a Broan 502/503 side discharge fan and it rattles when the fan is turned on. All fittings are tight, and when we put some pressure on different parts of the fan housing - the rattle continues unchanged, so we believe it is the damper that rattles How can we get this rattle to stop?
Thanks!
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
SOURCE: Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
SOURCE: 98 Corolla Rattling
timing chain tensioners are commen on the 1zzfe. the tensioner is about $50 and the labour another .5 hours.
Something is obviously loose. It may be the fan. See this diagnostic article on this topic:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
Hope this helps.
Brad
