Heating & Cooling Logo
Cathleen Manna Posted on Sep 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E2 flashing but unit is working. What is the problem. Newair AC 12000E, 12000H
richie46
Level 3:
Top Expert:
  • NewAir Master 12,962 Answers
  • Posted on Sep 08, 2015
richie46
NewAir Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2943311
Points
58151
If everything is working fine, I would simply ignore the false indication that something is wrong.
If it makes you feel any better you might want to check the manual for this code or go the manufacturer web site for assistance.
Elegance 14000 BTU Portable Aircon ELPA14CH red light?
Question edited for clarity and typo 'but' to 'BTU'.
Question moved from Video Game Consoles.
It is likely 2 things
Water tank needs to be emptied.
or
Filter needs washing.
https://www.google.com/search?q=Elegance+14000+btu+portable+aircon+Red+light+is+flashing
https://manuals.appliancesonline.com.au/mpf14crn2/mpf14cen2.pdf
1helpful
2answers
My NewAir 12000E got hit by a power surge. The plug light is green when I plug it in, but the unit does not even turn on. The company informed me the circuit board is probably blown. Would it make sen
check the cheap stuff first like all fuses and if they are ok check wiring and then if all is good change the board. if you were asking what you should do then there ya go! i didnt really see a question in there
2answers
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
1helpful
My air conditioner has stopped bliwing cool air
my unit turns on and u hear the compress try to turn on and it goes off ....but the fan still blows ...
1helpful
I just received this air conditioner. Set it up
It sounds like you have a faulty unit, that has a bad built in thermostat. I'd suggest sending the unit back for a replacement, or get a refund, & buy another unit. What you may think is the compressor kicking in, might just be the blower fan. Try raising the temperture as high as it will go, & see if you hear a noise change to quieter. If it does get quieter then the compressor was in & is not working properly. Send it back.
How wide is the exhaust tube?
You cannot restrict the exhaust duct size or you will restrict the air flow and thus reduce or stop the cooling. It might even ruin the unit.
Too noisy hard to watch tv or sleep
Raise the setpoint a couple of degrees, this will cut down on the noise of the compressor, put fan speed on low and that should cut down on blower noise.
Make sure you have some rubber pads underneath the unit and that should cutdown on vibration.
1helpful
Water coming out of back hole.
dont cap it. you could fit a hose and drain it somewhere.
In normal operation the water is picked up by the fan and vapourised
1helpful
We have to empty the water frequently, is there a way to cut down on how often we have to do this?
If the a/c is always in a single spot in the room you can extend a hose going out. Another suggestion would be putting a pump on the bucket pumping out water so that it would automatically empty itself. A small aquarium pump would do.
I hope this helps
Air conditioner will not turn on
unfortunately you would have get a tech out there to take a look at it to many reasons
Top NewAir Heating & Cooling Experts
Paul Carew
john h
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
